Return air
Return air
Hi All, I am thinking of cutting a return air opening in wall for my AC so that I can remove the louvered door that is currently there hoping to cut down the noise,this is Fl. And AH is in a room off the living room ,the AH using a 20X20X1" filter,can I somehow use that size to figure what size to make the opening?
Geo
Geo
The size opening needs to be at least that big. Unfortunately you'll need to reframe to get a 20" wide opening between 16" OC studs unless you make the opening like 15" x 30"
No problem reframing , just wondering if using the filter size would be a good guide , I iI frame it larger anyway.
Geo
Geo
