Testing Rotary Vane Vacuum Pump - How to?
Hi,
Is there a way to test a rotary vane vacuum pump without buying n expensive tester?
I just bought a cheap rotary vane pump for a cow milking machine. It briefly worked yesterday but not now. I'm not sure if it's part of the milk machine or the pump.
Any help would be great. Thanks
All it would take is a basic automotive vacuum tester. Many are called vacuum and fuel pressure testers. Most measure down to 30 in/Hg. Your vacuum pump should probably be around 20-25 in/Hg.
This one is from harbor freight but any automotive parts store will have them.
harbor freight/fuel-pump-and-vacuum-tester
Rotary vane pumps are equally good at generating a vacuum as they are at creating pressure. A real simple test is to put your finger over the outlet or inlet and feel the suction or air blowing out. Rotary vane pumps have fragile solid carbon parts inside. If the pump were dropped or if it was run without a filter on the inlet a piece of debris can get sucked inside breaking the carbon vanes.
