Spray foam on ceiling
Is there any spray foam to spray on the ceiling to add insulation. The ceiling is level without a slope. I was looking at something like this.
Hi Michaela. We will need some more details to be able to properly advise you.
When you say ceiling is this a drywalled ceiling with an attic above or are you referring to rafters where the shingles are on top?
We also need your climate location to know if heat or cold is your concern?
Describe the house if you can.
Bud
Bud
I believe a ceiling to be the inside portion of what is above your head on the inside of your house.
If you want to spray foam on the ceiling inside the house then no, not a good idea.
If you are referring to the upper part of the ceiling that resides in your attic then yes, it could work insulating this area with spray foam.
As asked, provide detailed info on your house to better help you.
