flex duct skin is crumbling
Old 09-21-18, 09:51 AM
P
I have 8"-12" flex ducts running in the attic. The skin (?) is flaking off, I mean small shiny pieces. What can I use to wrap these ducts with?
Thank you.
Old 09-21-18, 10:04 AM
P
Received 1,952 Upvotes on 1,748 Posts
Best and easiest would be to replace the duct. If the shiny pieces look like really thin aluminum foil the reflective aluminum layer is separating. You can try wrapping it in tape but there is only so much you can do. I would just let it go or replace with new duct material.
Old 09-22-18, 07:07 PM
P
The "easiest" way seems to be replacing the whole thing. Thank you, Will do.
