inaccessible duct needs insulation
Old 10-23-18, 09:25 AM
D
i am sweating in Texas. large (say 16" or so diameter), round, metal supply duct between first and second story 10ft run , framed out and accessible from top and bottom.
insulation has fallen off and is sweating
wonder if i blow loose insulation, fill the entire space, will that stop the sweating? imagine it will settle over time but i can always reapply.
there is no way to wrap the pipe with insulation, correct me if im wrong
other option is to run a new flex line.
your thoughts?
Old 10-23-18, 10:37 AM
P
Received 749 Votes on 688 Posts
Foam would be the best since it would be vapor barrier and insulate and would not settle. If there is access from above they can squirt their gun into the opening and foam it up in layers.
Old 10-24-18, 12:38 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Like pilot said id spray it with closed cell foam.
