Mini-split in shed, do I need gable vents to remain open?
My 12' by 12' traditional gable roofed shed has a gable vent on either end. I have insulated and finished the walls and ceiling and I am in the process of installing a mini-split system for heating and cooling.
Question: Do the vents need to remain open or should they be sealed off?
Thank you
Thank you
Definitely close the vents. It's the same as having a window open. OK, when the shed was not conditioned but with heat and AC you want to close it up.
