How do I get the cover off this bathroom exhaust fan
Old 08-24-19, 04:12 PM
K
Iíve been trying to remove the cover to this exhaust fan without success. Itís installed in a high ceiling above a glass shower, so the ladder that will fit in the space is not quite tall enough for me to be able to really see (I can just barely reach it from the ladder). Iím afraid of damaging it if I just go yanking on it. Any tips would be appreciated. If it helps iím guessing the fan is original to when the house was built in 2001. Thanks!
Old 08-24-19, 04:38 PM
Norm201's Avatar
Received 729 Upvotes on 644 Posts
Most likely there are two wire springs that will slip through brackets inside. Usually you just pull down.
Can you slip your fingers under the edge and does it give a little?
Look at this
https://images.homedepot-static.com/...fe5d37d498.pdf
Old 08-24-19, 05:31 PM
XSleeper's Avatar
Received 1,979 Upvotes on 1,774 Posts
If it doesn't pull down , someone probably painted it to the ceiling. Cut around it with a utility knife and bump it sideways with your fist. Once its loose it will pull straight down to unhook.
Old 08-25-19, 06:06 AM
Tolyn Ironhand's Avatar
Received 916 Upvotes on 774 Posts
If none of that works you may have to rotate the glass counter-clockwise.
