Bathroom Exhaust Fan Replacement
Old 09-03-19, 04:51 PM
Received 1 Upvote on 1 Post
Hi folks,
My exhaust fan recently died. I took off the grill and removed the motor/fan and I'm left with the picture. Any idea how I can get the actual housing out? I doubt I can find a replacement for just the fan/motor, so thinking the whole thing has to come out.
This is in a condo, so I don't have access to an attic to do it from above.
Thanks
Old 09-03-19, 05:00 PM
XSleeper's Avatar
Received 1,811 Upvotes on 1,628 Posts
You will have to cut out some drywall to disconnect the bracket it's on.
Old 09-03-19, 05:05 PM
That's what I was afraid of.
Old 09-04-19, 04:43 AM
P
Received 1,952 Upvotes on 1,748 Posts
Have you tried looking for a replacement? There are replacements available for many fans and even if you can't find one specifically intended for your vent box you might be able to make it work.
joecaption voted this post useful.
Old 09-04-19, 04:04 PM
maarkr's Avatar
Received 23 Upvotes on 20 Posts
i had a fan in a past house that got noisy every few years, so I'd replace the fan... not a hard thing to do. I finally got fed up with it and installed a new unit... not an easy thing to do cause they don't fit exactly the same.
Old 09-04-19, 04:14 PM
Yeah, I initially couldn't see what brand it was because it looks like some paint or something was sprayed over the label after it was installed.
I googled all the numbers I could see on the motor itself and to my luck they still make them (it's about 7-8 years old).
Just ordered one and it will be plug and play.
