Cold air return - 2 furnaces
Old 12-06-23, 11:36 AM
C
I have 2 furnaces and am confused about my cold air returns. I have one room that is connected to furnace A and the same rooms’s cold air return goes to furnace B. Is this ok - or is this a problem?
Old 12-06-23, 12:49 PM
P
Received 2,185 Upvotes on 1,955 Posts
So, do your two furnaces share a common cold air return or are there two separate air return systems that do not coincide with where the heating vents (cross connecting)?
Old 12-06-23, 01:26 PM
C
they look separate - but the one room I have opened up is definitely going to the other furnace.
Old 12-06-23, 01:58 PM
Received 3,986 Upvotes on 3,578 Posts
To get the best circulation you'd want the return to be on the same furnace as its supply.
Old 12-06-23, 02:35 PM
C
understood! but that would require a lot of rework - there was a reason they did it like this lol. Is it a deal breaker like this? (not sure how this work passed an inspection)
Old 12-06-23, 03:44 PM
The inspectors don't look for things like that. That's up to the installer.
The inspectors look for things like duct fastening, sealing, flue ducting, gas line treatment.
Is it a deal breaker.... probably not.
Old 12-07-23, 06:08 AM
P
Since that room is cross connected you need to make sure there is ample air return available. Worst is a tight fitting door that won't let much air leak past. That can be fixed by cutting a few inches off the bottom of the door to allow the air to get back to the correct furnace.
