Kenmore elite ice maker
Closed Thread
Old 02-22-04, 06:54 PM
gatech84
Arrow Kenmore elite ice maker
The ice maker on my side-by-side has quit working. No water is being dispenced into the ice maker. The unit has power and is working. The timers seem to be correct (manually filled unit with water and it made ice). The in-door water dispenser works fine. Does anybody have any ideas what is wrong and how to fix?
Old 02-22-04, 07:34 PM
appliancepresid
Hi, a couple of things to do would be to switch the wires on the water inlet solenoids. there is a dual water valve with units with ice and water in the door models. by switching the wires then press the water lever on the door for ma couple of seconds then check the ice maker to see if water entered.
if not check the fill tube if fozen, not allowing water to enter.
may have a leaking water valve and freezing or if water has been turned off the fill tube can freeze up.
but switch wires first it will tell a lot.
hope that helps if need more info type back.
Old 05-07-14, 11:16 AM
L
I have the same problem, no water being dispenced into the ice maker. I thought it was the ice maker componant so I bought a new one and installed it. I have no idea what the issue is and even if it was necessary to buy a new icemaker unit. How do I find out why the water does not go into the unit? Please help. Thanks
Old 02-04-16, 03:59 PM
D
So please tell me, if the line is freezing, what is the fix? Thanks
Old 02-04-16, 06:26 PM
Received 1,185 Votes on 1,097 Posts
This thread has nothing to do with a freezing water line. We'll address your problem in the thread you started.
Closed Thread
