Commerical maytag washer
Old 05-05-16, 04:30 PM
Danny258's Avatar
I have a commercial washer that stops at the deep rinse cycle I have replaced the timer but still does the same stops at the deep rinse cycle I have also jumped out the lid switch but still does the same I am lost what to check next
I have access to all the parts can you help me check the next step indecently
I have two washers doing the same thing
Thanks Danny258
Old 05-05-16, 04:52 PM
Received 77 Votes on 72 Posts
And the model number is?
Need that before making some guesses.
Contacted Maytag yet?
Old 05-05-16, 06:27 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
need model # check that there is cold water coming into washer. Rinse is only cold water.
Old 05-11-16, 04:37 PM
Danny258's Avatar
I have 10 washers and two out of them stop at the Deep rinse cycle Model # MAT15MNAWWO
Old 05-11-16, 04:52 PM
Danny258's Avatar
MAT15MNAWWO I have checked the cold water in both washers its ok
Old 05-11-16, 06:33 PM
pugsl's Avatar
They say Maytag on them built built by Whirlpool. Most Whirlpool parts will fit them (usually cheaper). Just for your info. Not a common problem but sounds like timer. Here is a diagram of your washer
MAYTAG WASHER Parts | Model MAT15MNAWW0 | Sears PartsDirect
Google timer parts # and only buy from a seller that as a year return policy. I can't be sure it's the timer
Here is the timer part # W10130353
Old 05-12-16, 03:18 AM
pugsl's Avatar
Does the cold water enter the washer on rinse? I know you said cold water works.
Old 05-15-16, 06:17 PM
Danny258's Avatar
Thanks I found the problem it was the cold water solenoid was bad Thanks
Old 05-15-16, 06:21 PM
Danny258's Avatar
Thanks I found out the cold water solenoid was bad thanks for your help
Old 05-16-16, 03:37 AM
pugsl's Avatar
Thanks for the update, Glad you found the problem.
