Black residue on clothes from washer
Old 06-05-16, 07:42 PM
X
I have a Calypso washer. Lately I have noticed some black marks on a couple of items after the wash cycle. It looks like grease, but doesn't feel greasy. I've checked all around the inside of the washer, but can't find anything. Not sure where this stuff is coming from. Any suggestions?
Old 06-05-16, 08:40 PM
Received 3,759 Upvotes on 3,370 Posts
Welcome to the forums.
It sounds like there may be an issue with the wash plate support or the u-joint may have failed.
The only way to know for sure is to have the inner wash plate removed & inspect the drive components.
When you wipe the tub down with a white rag.... is there black residue on the rag ?
A model number would be helpful for your washer too.
Old 06-06-16, 04:37 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
model # needed there was a software update for this problem many years ago. If you still have a Calypso still working you have outlasted there life time.
Old 06-06-16, 09:27 PM
X
Model # 110.2206.
No residue when I wipe it down. The black stains are just on a couple of of items.
I've had this machine for 15-years and up to now has kept on working.
Old 06-07-16, 04:48 AM
pugsl's Avatar
Cross your fingers, great machine when works but many problems with them.
Old 06-12-16, 06:30 PM
X
Pix of Stains from Washer
Here is what the machine is doing.
Old 06-13-16, 05:12 AM
pugsl's Avatar
Looks like you have a build up of dirt in washer. It's a big job to tear down and clean. Most likely you will need parts also. Almost sure a U Joint . Just looked up U Joint and it's no longer available from sears.
