Inner Door Oven Glass Cleaning - can't get to it
I have a Maytag Oven model MER5875RAB and have begun the process to clean the inside glass.
The inside two pieces glass appears it is held in place by a frame (attached). Can this be removed to get to the inside of the each glass which is dirty?
thanks
thanks
That shows as the inner glass panel and it's shown as separate from the outer glass.
Maytag Range MER5875RAB Parts List
Thanks ..
I was able to remove the frame by bending the small tab back shown at the end of the frame. This allowed the frame to come apart and I removed both glass panels, cleaned them, reinserted them and bent the tab back in place.
