Dryer Leveling Legs Hole Bent
Old 12-16-16, 02:17 PM
L
Question Dryer Leveling Legs Hole Bent
Movers must have slid dryer and legs caught on something forcing the legs to bend the metal and the legs are now crooked. I know I need new legs and I'll try to hammer on the metal around the holes to make it as straight as possible. The flooring where the dryer is located is kind of soft, probably cheap linoleum and now the crooked legs dig in a little as I slide the dryer into position. I probably won't be able to bang the metal out enough to make the legs sit flush on the floor, so any advice on any facet of this is appreciated.
Old 12-16-16, 02:26 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
any of these under legs would work. Dryer is not heavy.
https://www.lowes.com/search?searchT...ture+skid+pads
Old 12-16-16, 02:56 PM
Received 77 Votes on 72 Posts
Before I did anything I'd try running the dryer to see if it's even an issue.
Old 12-16-16, 03:17 PM
chandler's Avatar
Received 6 Votes on 6 Posts
One trick to straightening the holes if you need to, is remove the existing skid feet and insert a grade 8 bolt of the same thread about 3" long. You can bang on that bolt without messing up your feet. Then remove it and insert your feet.
Old 12-16-16, 03:32 PM
L
Thanks, this sounds like the right first step.
