GE front load washer
Have a 2006/7 GE front load Hydro Heater Washer. Has an intermittent squeal at low tub speeds...a louder clunk at higher speeds, in time with tub revolutions. Sounds like a bracket has holding the tub, has broken....like a broken motor mount. No squeal/clunk if clothes are balanced. Does the front panel below the door have to be pried off at a certain side or point....? No luck trying from the right....so, left....?
Thanx
Charlie
Thanx
Charlie
Post model # I think on that one it is on the right side near bottom. Need model # to which washer you have. Before you go to that trouble reach inside door and lift on stainless basket. Should not move up and down in plastic tub. If any movement bearing is going bad. Whole plastic tub should move. Also turn basket by hand it should feel smooth.
