In-Door icemaker tray full but can't eject ice
Old 01-24-17, 12:19 PM
B
Kenmore Grab-N-Go Model#795.7053 Ice tray is frozen but won't eject. When I turn the ice maker switch off then turn back on I can hear the motor run and see the tray starts to turn and stops as if something in the way stops it. Seems to have happened after I dumped the ice bucket into a cooler .I've removed and replaced the bucket several times to be sure it is seated correctly to no avail. Cold water still runs but maybe not as fast. would a plugged filter cause ice problem? The problem really seems to be something binding the turning of the ice tray. ?????
Old 01-24-17, 12:33 PM
Received 1,113 Votes on 1,033 Posts
There will be a button under your LG icemaker. It's a test button. Push it.
The tray should do it's thing and then it should fill with water.
Name:  lg icemaker test.jpg
Old 01-24-17, 02:06 PM
B
In door ice maker.
Thanks, I pushed the button and the tray rotated. now I'll wait till it freezes and see if it dumps the ice and report back.
Old 01-25-17, 10:08 AM
B
in Door ice maker
okay.Yesterday i pushed the test button and the tray rotated and dumped ice. This morning I checked and no new ice. pushed the test button again and it dumped the ice. ???? When I turn the icemaker off and again on it tries to turn and goes back as if to reset. ??? Can't find any info on any repair of unit that mite help in finding the cause of the binding.
