Kenmore Laundry Center
I just purchased Kenmore High Efficiency 27" Super Capacity 3.8 cu. ft. Gas Laundry Center and the water flow is so slow that it will not turn on my tankless water heater.
The hoses are installed correctly and water is running through the heater, but just too slowly.
Is there a flow control setting to increase water through the machine?
The water heater is work fine it is just the Kenmore water flow is so low.
The old washer had no issues
Take the hot water hose of the washer and either put it in a bucket or the washer. Turn on water and make sure the flow is good. If good there is a screen inside the fill valve end. easily taken out and cleaned. Be sure to put screen back in. If still a problem you have a year warranty I would call repair or store you bought washer from and either get it fixed or replaced.
