Loose undercounter dishwasher
Old 10-13-17, 01:46 PM
N
Hi,
My dishwasher has become loose from the countertop. I think the steam vent has made the countertop soft above the vent. Any ideas hot to reattach the bracket?
Thanks
Old 10-13-17, 02:13 PM
Received 2,949 Votes on 2,662 Posts
There should be two brackets about an inch in on each side. Sometimes you can remove the screw and slightly twist the bracket to put the screw in a new hole. Other times a slightly longer screw will work. Just be mindful of the length of the screw so that it doesn't come thru the countertop.
Old 10-13-17, 02:21 PM
pugsl's Avatar
Received 76 Votes on 69 Posts
If counter top to bad most DW have side mount holes. Take top brackets off and move to side, Usually there is a plastic plug to remove to put in screws.
