Kenmore model 9535580 fridge: light switch replacement
Old 11-10-17, 01:31 PM
B
I have a Kenmore 9535580. The light switch is bad. Can any one tell me how to take it out?
Old 11-10-17, 03:47 PM
Received 3,992 Upvotes on 3,583 Posts
You missed the first three digits in the model number. That's the manufacturer.
XXX.9535589 Probably 106.9535589 which is Whirlpool.
The switch is OEM part # WP2149705.
The switch is held in place by two wings. It's usually best to unsnap it from the back. The following video may not be your exact fridge but the switch is identical.
you tube/watch?v=T-gY5ZvdkT0
You can click on the following link for an exploded view. After it opens select the "control" tab. The switch is pictorial part # 4.
sears parts direct/model-number/1069535580/0582/0160000.html
Old 11-10-17, 03:48 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Model # did not work, there should be a 3 digit number in front of model # looks like this xxx xxxxxxx
Also what is it, Helps to know what appliance it is.
