Maytag CRE9800 - oven and broiler don't turn on
Old 05-08-18, 10:38 AM
O
The elements work fine. I set the oven temp and 3 seconds later hear a click and the display dims (slightly). 5 seconds later another click. The temp stays at the minimum - oven never heats.
First time I had the problem it got up to about 200 degrees and then cooled down. Now it doesn't heat at all.
I checked the temp sensor - it's good.
Suggestions for next step?
Old 05-08-18, 07:15 PM
Received 1,522 Votes on 1,405 Posts
That is the appliance group number..... not the complete model number.
I need the missing suffixes to look up the right control board.
I'm assuming the stovetop burners are working normally ?
It sounds like a failed relay on the control board.
Old 05-09-18, 08:41 PM
O
Is CRE9800ADE what you're looking for? (And yes - stovetop burners work fine)
