GE Triton XL dishwasher won't drain
Old 12-29-18, 07:08 PM
P
16 yr old dishwasher Model GSD6700G00GB has never needed maintenance, but now won't drain completely. Fixed the drain line by raising it higher than the disposal; but it's not getting warm so the water isn't reaching it. Tried the baking soda/vinegar several rounds, then boiling water. No kinks in hose. Dishes seem to get clean; but after cycle, water sits up to door. Can see the motor spinning fast when front panel is removed; could there be a second motor for the drain?
thanks!
Old 12-29-18, 10:57 PM
Received 1,203 Votes on 1,113 Posts
I couldn't find that model number..... so I used.....GSD6700G00BB.
That unit does have a separate drain pump. It's 325 in the pictorial. It's connected to the sump with a flapper (check valve) and a clamp. You may have to remove the pump assembly from the sump to find the clog. Also make sure the motor is actually running when in drain mode.
sears parts direct/gsd6700g00bb/parts
Exploded pump view (After opening link.... click on diagram for expanded view.)
Old 12-31-18, 10:47 AM
P
Thanks so much for the guidance, Pete! Very useful and encouraging.
learned the drain pump is not running at end of cycle; so have ordered a replacement that will arrive in two weeks. Not looking forward to handwashing dishes but...
Happy and Peaceful New Year Pete!
