Kenmore electric range oven does not heat above 325
Received 0 Votes
Kenmore model 790.96593601 Oven heats sporadically, sometimes works normally but more frequently will not reach high temperature. Element and temperature probe test OK. I suspect it is the control panel. Is there a way to test the control panel?
I would agree there is a control board problem in that Frigidaire built appliance. The control board needs to be removed and visually checked. In the picture below I've drawn a box around the problem area. You will more than likely find the terminals where the wires connect or the relays solder burned/defective.
If you're handy with a soldering iron you can fix it.
Post some pictures of what you find.... How-to-insert-pictures.
A similar thread...... frigidaire-fgef3055kfb-range-oven-not-working.
