Dryer problem
Old 04-06-19, 08:57 AM
D
Dryer problem
So I have a armana dryer and having the issue of my dryer not working I have power going from the sub panel to the outlet but nothing to the dryer any ideas of what I can try
Old 04-06-19, 11:18 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Post model # and can help. A Quick check is to look at where cord enters dryer , Take plate off and see if any are burnt wires. Most dryer problems start with a clogged vent to outside. This needs to corrected or same trouble will happen again.
Old 04-07-19, 11:28 AM
D
Vent
I checked the vent no clogs anywhere in it I vacuumed it all out but still clear
model number is NED4655EW1
Old 04-07-19, 12:51 PM
pugsl's Avatar
You have a Amana dryer made by Whirlpool, Reason I say this is almost all whirlpool parts will fit and are usually cheaper. Diagram I will post Part #7 under bulkhead is thermal fuse. With ohm meter kit should show closed. If open it's bad. You need to take back panel off and it is located on tube on left side near bottom. I think it has 2 blue wires to it. Most common reason dryer won't run.... Click all parts to see. Real bad diagram
https://www.searspartsdirect.com/mod...1-dryers-parts
