dishwasher thermal fuse keep blowing.
Old 12-28-19, 02:40 PM
whirlpool gu2300xtvq1
Power go out during wash cycle and leave water in the tub.
Old 12-28-19, 03:15 PM
Received 1,482 Votes on 1,370 Posts
Did you replace the wires and connectors when you replaced the thermal fuse ?
A loose connection on it will cause a new one to blow out quickly.
Old 12-30-19, 05:01 AM
hi pjmax,
i checked the wiring to and from the thermal fuse. there is no loose connection or burn marks. anything else to check?
jlao41859
Old 12-30-19, 06:04 AM
Received 161 Votes on 148 Posts
When you received the replacement fuse it should have come with new wires/connectors.
You have to use those.
Otherwise there is no way to be sure that it is not a machine problem or the known and frequent failure of the original fuse assembly.
Old 01-09-20, 05:12 AM
hi pjmax and manden,
i have been ordering the thermal fuse alone without the wiring harness, because my unit did not have the similar harness to replace. Then i heed your similar advises and look for a thermal fuse for my unit with a wiring harness.
the internet also told me that the wiring harness will act like a heat sink to prevent the fuse from blowing and that you also have to splice the wiring to the thermal fuse to install the new thermal fuse with wiring harness. I have installed the new thermal fuse together with the wiring harness and have ran 3 full dishwashing cycle without blowing a fuse. thanks for your advise.
jlao
Old 01-09-20, 06:47 PM
Good job. Name:  thumb.jpg
Size:  1.6 KB Thanks for letting us know how you made out.
