Clothes dry too quickly
Old 03-23-23, 06:13 AM
L
Received 10 Upvotes on 10 Posts
I am having an issue with my 2005 Maytag dryer, model sde3606ayq, serial 18053754gc. The problem is that the clothes dry completely long before the timer reaches the off setting. The owners manual states the control knob advances slowly when the clothes are wet and advances more quickly as the clothes begin to dry.
The timer advancement seems not to be working due to the clothes being fully dry so quickly. This wastes a lot of electricity. Is this strictly a timer problem (worn out?) or is there a sensor that signals the timer to advance or some other remedy? Is it a repair I can reasonably undertake myself?
Thanks
Old 03-23-23, 06:43 AM
T
Received 112 Upvotes on 100 Posts
I suspect your dryer model is sde3606ayq. If so, it has a moisture sensor which is probably your problem and costs about $50. It may also be a dry timer device which is considerably more expensive: $150-200. The timer regulates the time so it could be the timer, as well.
Old 03-23-23, 06:52 AM
L
Yes, its 3606. Thanks for your information.
Old 03-23-23, 01:07 PM
Received 4,154 Upvotes on 3,730 Posts
Some confusion with this electric dryer.
In looking at the schematic and parts diagram for this dryer.... there is no moisture sensor shown.
Your dryer requires a RS3200007 tech sheet which will be somewhere inside the dryer.
Typically on the back or inside where the timer is located.
There is a moisture sensor shown in the service manual but that may be in the gas model only.
RS3200007 downloadable manual
I believe your dryer uses a sensor heater to anticipate auto heat.
WP37001136 thermostat (cycling) three terminal
61623 thermostat heater
37001133 - 240 limit
WPW10116735 - 225 limit
WP503979 - 155 limit
