Glass cooktop replacement
Old 04-18-23, 11:11 AM
Z
Hello,
we have a kitchenaid electric glass cooktop. It has a major crack but is still functional.
I don’t have the full model # but it’s in the KECC568 family.
I’ve found a similar model on Facebook. It’s from the same model family. KECC568RPS01.
the seller doesn’t know if his unit worked. Never installed it. I’m interested in installing it OR using its glass as a replacement.
My unit has a slightly different burner design.
has anyone replaced the glass before? Would a similar, but not exact glass work fine? Are the controls below the glass or on the glass?
pictured below is my unit and the possible replacement
My existing unit
Possible replacement with different burner config
Old 04-19-23, 04:25 PM
Received 3,759 Upvotes on 3,370 Posts
I've replaced the tops but not using a "similar" model.
The KECC568RPS is the model in your "new" picture. The S stands for stainless trim.
The KECC568RPB is more like your old top. The B stands for black.
The KECC568RPW is white.
When I research older models I'm coming up with Whirlpool W10140999.
If you look down at the bottom of the page... it shows all the old model numbers.
I think you're going to have to lift your unit up to get the actual model number.
Old 04-19-23, 04:29 PM
Z
Found it. Mine is a KECC568MSS01.
Old 04-19-23, 04:51 PM
8285315 black
8285390 - white
8285391 - Biscuit
8285392 - stainless steel
Old 04-19-23, 04:56 PM
Z
So would you attempt to swap the glass on these two?
Does the glass have markings (circles, numbers) or is that below the glass?
I assume the actual controls are below the glass?
Old 04-19-23, 05:03 PM
Everything is below the glass.
The markings are where the cookware goes.
However, the openings are not exactly the same so I don't know if you can swap the glass.
