Plastic film on stainless steel?
Old 04-29-23, 09:33 AM
E
Hi all! While doing some deep cleaning today, I tried to remove some cloudy residue around the handles of our Whirlpool stainless steel fridge. I was unable to so I removed the door handles to get at it better.
Upon doing that, I started to raise some plastic film with nothing more than soapy water and a sponge. Now I'm concerned because it looks like I can go on and on with this plastic film.
I have a hard time believing it's the original film (fridge is only a few years old), but I have a hard time believing it can be anything else. I'm assuming stainless steel usually wouldn't have anything like this that can be removed?
Do I just keep going?
Old 04-29-23, 12:22 PM
P
Received 1,954 Upvotes on 1,750 Posts
Polished stainless steel is often covered in a thin layer of protective plastic. The brushed finish is surprisingly delicate and easy to scratch so the plastic is usually left on all through manufacturing and not removed until in place in the customer's home. Look on the bright side. It should be squeaky clean and new looking underneath.
Old 04-29-23, 12:26 PM
E
Thanks Dane. I just have no clue if this is intended to stay on or be removed - have a hard time believing we wouldn't have removed it but it is around the handles. It's pretty noticeable and super time consuming to remove and not sure I want to proceed. I'm sure if it is this layer you mentioned, the UV rays have gotten to it over the years. We have never noticed this before and now it's super annoying!
Old 04-29-23, 12:38 PM
E
Top picture is what the freezer handle looks like and this is what caused me to pull the handles off. The top picture is what the fridge doors currently look like. Now I'm not sure what to do 🤷‍♂️🤷‍♂️
Old 04-30-23, 03:20 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
​​​​​​​It comes off!
Old 04-30-23, 06:04 AM
Received 283 Upvotes on 254 Posts
I would contact Whirlpool just to be sure about it.
Try warming it up with a hair dryer.
Be careful to not overheat it.
Should make it easier to remove.
Then check for any residue if there is I would clean it with isopropyl alcohol or whatever they say in the manual.
Old 04-30-23, 07:58 AM
P
The film can be more difficult to remove with age or if it's a room that gets some sun exposure. But, some fridges may intend for the plastic to remain to help offer "no fingerprints". But, if your plastic has started coming off... your committed and might as well take it all off so it has a uniform appearance.
Old 04-30-23, 03:58 PM
Received 3,632 Upvotes on 3,254 Posts
The glue from the protective coating can be almost impossible to remove after several years.
