Hey Guys. Can you help me out with ideas for (yet another) problem with my Samsung French Door Refrigerator? The way it's supposed to work is when you close the left door (the one with the hinge, photo 1), there's a piece (photo 2) that's supposed to slide into a guide (photo 3) that pops the hinge back into a closed position so there's a seal on the fridge. But on mine , just now after many years, the piece is missing the guide low and away. Is there a way to adjust the door? It needs to move maybe a mm or two up and to the right.
Yup, there's more to the model number...an RF in front. But, I got the shims already and they worked easily and perfectly. Thanks, PJ, as always for the help.
[color=#141414]This began with a burning smell, and a screaming sound during drain, however it did get to the end of the cycle. Now, symptoms are clear and repetitive. It agitates, hits spin, but only spins 15 seconds and stops. It repeats this three times after one minute pauses, then there is 15 minutes of ticking until the timer gets up to the KNIT part of the dial and the washer will begin to agitate again. Timer won't stop--goes around and around. Impeller turns freely. Checked hoses for blockage. What is interrupting that drain and spin cycle?[/color]Read More
whirlpool top load WTW4816FW3
Just got this machine, ran a load or 2.
On the next load, I opened the lid to add something and see that the wash basket is now inches lower than it had been, creating a gap of several inches below the top of unit and exposing the interior of the washer.
I am new to HE washers, so maybe this is normal? The only other thing is that I did change the cycle from normal to bulky after it started (while paused) as I was trying to figure things out, mainly why the laundry (towels) were not fully submerged in water. I would not say that it was a full load of towels, btw
I called whirlpool support and they had no clue.
Read More
