Shark Navigator (Vacuum) acting like its clogged.
Old 03-21-16, 08:10 PM
I have of course checked all the hoses, emptied the canister, cleaned the screen in the canister, cleaned all the filters and check the brush for blockages. These are all clean and clear.
When I turn the machine on it sounds perfect for 2 seconds then it sounds just like putting your hand over the hose with its "Never lose suction" technology. It still sucks but not as well as it should.
I don't want to be without a vacuum sending it in for a couple weeks so any help would be appreciated.
Old 03-21-16, 08:22 PM
Received 1,330 Votes on 1,229 Posts
There seems to be several models in that series.... can you narrow the model down for me.
Old 03-22-16, 10:04 AM
Model number
Nv46c 26....thanks for looking into it
Old 03-22-16, 10:45 AM
I couldn't find much info on the NV46. A lot on the NV22. Similar models.
When you run the vac with the hose unplugged.... do you get the same problem ?
Old 03-22-16, 11:02 AM
Shadeladie's Avatar
Super Moderator
Received 141 Votes on 110 Posts
Do you have a long, flexible tube or something like it? I've discovered clogs in parts you can't see or reach and pushing something long thru the whole thing, ended up finding it and pushing it out.
Just a suggestion.
