Replacement microwave mounting problem.
Old 12-02-16, 02:44 PM
B
Old GE Mod. JEM31GA001 died. It was mounted from cabinet above and was over stove. I can’t find another under cabinet unit that is anyway near as low in height as the 10 ¼ “ of the old GE. The higher units get to close to the stove burners. There are many counter top units with the right height but I have to figure out the best way to mount a new one from the cabinet. I don’t want to put screws in the wall. The mounting hardware I found on line doesn’t look that great. Any suggestions?
Old 12-02-16, 03:05 PM
Received 125 Upvotes on 110 Posts
Anyone else confused?
"there are counter top units with the right height"
All new units will come with a new mounting bracket, so what's the issue?
Old 12-02-16, 03:53 PM
Received 3,480 Upvotes on 3,125 Posts
JEM31GA001....
800 w (1300watt) black countertop GE Profile Spacemaker II microwave
1.0 cu ft. 10.5"tall x 24"wide x 12"deep
The new replacement for that unit is only slightly taller. No idea on the mounting hardware looks.
GE Profile Series 1.1 Cu. Ft. Countertop Microwave Oven | PEM31DFBB | GE Appliances
Old 12-02-16, 05:30 PM
Handyone's Avatar
A picture of the upper cabinet will help, here's a link: http://www.doityourself.com/forum/el...-pictures.html
Your microwave wasn't designed to be above a range. It's for hanging under an upper cabinet or sit on the counter top, like a kitchen TV or radio.
Over the range microwave hoods are about 16" high and the upper cabinet would need modified/shortened.
The rule is the bottom of any combustible shelf or cabinet must be 30" above the cooking surface.
I would recommend a standard vent hood, which is about 6" high.
