Heat and food safe adhesive for kettle
Old 01-12-19, 11:47 AM
R
Hi there,
A non-integral plastic part of my kettle has come off, and I'd like to put it back on - it's a plastic part which affixes to metal. It doesn't have to be ridiculously strong as I fill the kettle from the spout.
Any suggestions?
Thanks, Robyn
Last edited by PJmax; 01-12-19 at 04:44 PM. Reason: resized/reoriented/enhanced pictures
Old 01-12-19, 01:52 PM
P
Received 2,327 Upvotes on 2,069 Posts
Is there a screw that goes through the kettle's lid and into the plastic part? You could dab some epoxy in the stripped out glue hole and insert the screw.
Old 01-12-19, 04:19 PM
T
Received 4 Upvotes on 4 Posts
Make sure the epoxy you get is heat resistant. Some loosen up at higher temperatures. Just check the labels.
Or you could use a stainless steel screw from beneath the lid into that plastic cap.
Old 01-12-19, 04:46 PM
Received 4,155 Upvotes on 3,731 Posts
If there is/was no screw holding that piece on..... use high heat silicone to stick it on. Since it's not in the water it doesn't need to be food grade. For the most part silicone is inert after it dries anyway.
