Carpet cleaner won't remove water
Old 03-21-23, 05:40 AM
D
Or, to lighten the mood, it sucks because it doesn't suck up.
Hoover model FH50150 cleaner won't vacuum up the water from the carpet. I removed the top of the unit from the bottom to expose the filter mesh, and found it was clogged with carpet fiber. I cleaned it, cleaned the rotary brushes, reassembled it, and it still doesn't remove the water. Any suggestions would be greatly appreciated.
Old 03-21-23, 10:57 AM
P
Received 2,106 Upvotes on 1,885 Posts
I would check any place something opens (tank) or you connect a hose. You are looking for a suction leak, possibly from a bad or missing seal or gasket.
Old 05-24-23, 01:39 AM
L
Hi!
Check the suction power ensure that the suction power is set to the appropriate level for extracting water. Sometimes, adjusting the suction settings can make a difference.
Old 06-05-23, 03:30 AM
Received 1,262 Upvotes on 1,203 Posts
DIY machines traditionally lack power to remove chemicals and water - our leases specify that the carpets in the unit need to be professionally cleaned upon move-out and that a DIY machine CANNOT be used for the job for this very reason.
