Bissell steam Mop NO STEAM
Old 06-26-23, 02:47 PM
Z
No steam opting our mop with the foot on or off. Kettle gets hot, but I think there’s a blockage somewhere. Cap on water tank replaced. Foot disassembled, no apparent blockage.
do they have common blocked areas?
Old 06-26-23, 04:50 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
Have you been using tap water in it, or only distilled water?
And does this model have a ready light? Is it blinking? Or on solid?
Old 06-26-23, 06:26 PM
Z
Both sources of water. Light blinks, then goes solid.
Old 06-26-23, 06:33 PM
XSleeper's Avatar
If you've used tap water in it, it could be gunked up with minerals.
Old 06-26-23, 06:59 PM
Z
I’m sure that’s it. Hoping to find some common areas of blockage,
Old 06-27-23, 12:04 AM
Received 3,749 Upvotes on 3,362 Posts
I added a labeled picture.
The flow goes from the tank thru the pump thru the boiler and then down to the sprayer.
Does the pump operate ?
The pump sticks thru a grommet into the water tank.
There is a piece of hose between the pump and the boiler.
Have you tried opening the cleanout cap at the bottom ?
You can troubleshoot the unit with cold water. Take one of the wires off the boiler.
You can remove the parts for cleaning.
2032652 - pump
