Over the range microwave malfunction
Old 07-31-23, 06:49 PM
K
Received 4 Upvotes on 4 Posts
The over the range microwave keypad locks every few months. I know it is from excessive oil that we use in cooking.
when it stops, I take out the top cover, the keypad assembly and blast some compressed air shots . I do not take off the entire keypad assembly since there are a bunch of cables connected.
Questions--
1) is it the right way to clean ( without removing the keypad assembly)
2) how do we minimize oil in it. I must say , that the range hood filter is very old ( 10+ years). I periodically clean it soaking on soap water , but I think time to change. Will changing it add life to the micro ?
Old 08-01-23, 05:47 AM
P
Received 2,228 Upvotes on 1,988 Posts
You could try sealing the holes and gaps along the bottom of the microwave to keep dirt & oil out. Maybe try white electrical tape over the seams & holes as a test to see if it helps.
Old 08-29-23, 05:31 AM
D
Received 3 Upvotes on 3 Posts
See where the debris is getting into the unit like the other guy said. Is it possible that the filter is getting overwhelmed?
Old 08-29-23, 05:39 PM
Received 4,051 Upvotes on 3,634 Posts
I doubt it's from oil. More likely steam.... condensation.
Blowing air in probably dries the condensation but doesn't clean anything.
Have you checked for any problems/recall on that unit ?
You could post the model number for me.
CircuitBreaker voted this post useful.
