Range outlet so far...
Old 02-03-16, 03:11 PM
G
Ok iv'e gotten this far and would like some advice. This is a range junction box/outlet install using 6-3 wire, 50 amp breaker. Looking for tips on the ground connection to metal box, how much wire should I strip back.
Thanks
Patrick
Old 02-03-16, 03:41 PM
Tolyn Ironhand's Avatar
Received 298 Votes on 258 Posts
First off you need more wire in the box. I would suggest at least 6-8" of free conductor hanging out. The outside jacket should be striped back so there is at least 1/4" inside the box.
Second, you just need to connect the bare ground wire to the metal box using either a grounding pigtail, or just a green ground screw. If you use the screw method, loop the ground wire around the screw and leave the end free to connect to the range receptacle.
Examples:
Ground screw: Ideal Combo Grounding Screw (10-Card)-774042 - The Home Depot
Ground pigtail: Ideal 12 AWG Solid Pigtail with Screw - Green (50-Pack)-30-3392R - The Home Depot
I also suggest installing a 2 gang mudring for ease of wiring and installation of the receptacle.
Screw goes in the green circled hole:
Old 02-03-16, 04:50 PM
pcboss's Avatar
Received 112 Votes on 97 Posts
Is that box 1 1/2" deep or 2 1/8"? It should be a deep box with a 5/8" 2 gang plaster ring.
Old 02-03-16, 04:51 PM
pcboss's Avatar
I really hope you have extra cable to slide into the box. The code requires at least 6" of free conductor in the box.
Old 02-03-16, 11:35 PM
Received 1,421 Votes on 1,314 Posts
You should use the deepest box you can find. Those range receptacles are deep and the wires are hard to bend.
