Conduit System Components - Help!
Old 02-22-16, 09:54 PM
D
I have a weatherproof electrical box that I want to mount on a fence. And I have a weatherproof electrical box that I want to mount on a post about 6 feet away. I have a trench dug between them already that is about 18 inches deep and the earth is soft and easy to dig.
The electrical boxes have 3/4 pipe thread. I have 3/4 PVC conduit for the underground portion. How do I connect the conduit coming up from the ground to the two electrical boxes? Since they have threads, something needs to turn, and the boxes can't since they are blocked by their mounting surfaces. I haven't seen fittings that are pipe thread on one end and PVC compression on the other. So I think I need to put the threaded components into each electrical box, then glue the two halves of the system together at a point that is away from the electrical box. Is that the process or am I missing something? This of course can never be disassembled. A list of components, starting at one electrical box, would be appreciated.
Old 02-22-16, 10:23 PM
Received 3,600 Upvotes on 3,228 Posts
You would screw 3/4" PVC connectors into the box(es) first. Then the pipe would be glued into the fittings. No need to have to turn the box(es).
Old 02-22-16, 11:42 PM
L
Received 195 Upvotes on 167 Posts
In addition to PJmax's answer, put some sort of thread sealant (same ones you use for plumbing) for additional water proofing. Both caps and male adapters.
I found rain water sometimes leaks in from the thread.
Old 02-23-16, 06:02 AM
D
Thanks.
How do I connect 3/4 EMT to the 3/4 pipe thread on the weathertight box?
Old 02-23-16, 06:25 AM
ray2047's Avatar
Use a rain-tight threaded adapter.
Size:  25.3 KB .
Old 02-23-16, 09:06 AM
If the fittings are screwed into the bottom of the box then no sealant is required. It's actually better to allow any lost water to be able to find it's way out.
Old 02-23-16, 10:15 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Are you using EMT or PVC??????????
Old 02-23-16, 02:25 PM
pcboss's Avatar
Received 175 Upvotes on 153 Posts
EMT is not for burial. It would rust out in a few years.
Old 02-23-16, 02:47 PM
ray2047's Avatar
I read it as EMT along the fence then PVC to the receptacle on the post.
Old 02-24-16, 04:06 PM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
I read it to mean the conduit will be buried 18 inches deep.
Don't use EMT underground.
