Sub panel: Yes, yet another sub panel question...
Received 0 Votes
Location: Firestone, Colorado (about 25 miles north of Denver)
I'm trying to determine a good placement for a sub-panel. The main panel is on the outside of my home, on a kitchen wall and behind the garage. There is a door about 12 feet away, into the garage, and I would like to place the sub-panel next to that door.
If I measure from the outer edge of the door frame to the nearest obstruction, it is 27", which would be 3" short of legal. But, if I measure from the door itself, then there are 30 inches. The door swings away from the proposed installation. The obstruction is a 5" OD radon pipe from the basement, that eventually proceeds out of the garage.
So, is this a legal installation location, or do I need to move to the opposite side of the radon pipe, where I can create plenty of spacing, but I lose shelving space?
I'll ask another question on sizing, but I'll limit this entry to just this single issue.
Thanks,
Eric
Thanks,
Eric
Since this thread is already started..... feel free to ask additional questions here. This is your thread.
Received 0 Votes
It's not the door that is the obstruction. It's the radon pipe. If you are saying that as long as the 27" of wall plus the "36" door means I have unobstructed space of "63", and I'll still be able to swing the panel door 90+ degrees, I guess that means I'm good to go.
Thanks,
Eric
Thanks,
Eric
Yes that is what I mean. Post a picture of the area just to be sure we understand what you have. http://www.doityourself.com/forum/li...rt-images.html Please adjust width of images to 1000px or less.
