Electric oven has to be on for kitchen lights to work
[ lights to work.The lites won't work, unless the oven is on.If i try the lites without the oven lite on,They won't work. Now. my wife says this wasn't happening before you started messing with the garage lite. In turn i says "You know absolutely nothing about what i am doing. So leave it at that... while i get help.So she 'll come home tonight and be abit sore ass ..Back to my problem.,Would this mean i may have a lite wire crossing the oven wire. one Circuit over another circuit> no sparks everything works...other that the garage circuit. Which i have about licked,thanks for looking bob s[/B]
I was mystified by a similar situation 25 yrs ago, some of my lights would only work when the water heater was on. In my case it was a break in the service cable [between meter and main breaker]. The electricians should be along shortly with more/better info for you.
Your wiring of the garage lights should not be connected to your problem.
As Mark mentioned....
You've lost a leg of your electric service. That means the electric stove should not be heating either...... is that correct ? All 240v appliances should be affected.
Call your power company emergency number now. Get them to come out and see if the problem is in their equipment .
This is a problem in the service entrance. Agreed the first step is an emergency service call to the power company. See if the guy will also take a look at your meter can and service panel while he's there. Next step would be to have an electrician check out your main panel and main breaker.
I would strongly recommend that you turn off all double pole breakers in your panel until the problem is fixed. This can cause damage to appliances.
Dead leg in main disconnect -i flipped the switch 200 amp several times- and electricity was restored .Consumers power said i should get new leads from the weatherhead in...........but if it ain't broke don't fix ir aayy thank you all for coming to my rescue bob s
I would assume you you are going to do something main disc. or breaker, if it failed one it will again at the worst possible time,
Just Saying!
Just Saying!
It will probably last 10-12- more years if i have that many left. One gets to a point in life.where has to weight the pros and cons on the money he spends....and the money he don't need to spend thanks all bob s
