contactor spade terminals?
Old 03-17-16, 12:44 PM
Z
What type of spade terminals do I need on the wire leads for this contactor (Lenox 95M55) ?
I ask since this the spade terminals I have I dont think are rated for over 15 or 20A.
Old 03-17-16, 01:05 PM
F
Received 36 Votes on 28 Posts
The "Faston" (not spade) terminals are rated for the largest size wire they will accept. Yellow terminals (10-12) are rated for 30 amperes.
Old 03-17-16, 02:46 PM
Z
so as long as the connector is yellow and accepts 10awg they are always rated for 30A?
Old 03-17-16, 02:56 PM
Received 1,197 Votes on 1,107 Posts
Yes...... the wire size determines the amperage.
Yellow is #10 for 30A max.
Old 03-28-16, 03:20 PM
Z
i used the 30A disconnects on a new contactor for the Line side connections....
got to thinking, should I have just wrapped the 10AWG stranded around the screw or is it actually preferable to use the blades and disconnects instead?
Old 03-29-16, 06:51 AM
Z
Still wondering if its perfered to wrap around the screw on these contactors or if its better to use the crimped disconnect terminals?
also-- general question in regards to the yellow 30A disconnects.... is it physically impossible to slide one of those over 8-AWG? Or like if someone made a mistake and tried to use a red one on a 10awg... are they only designed to fit over the rated gauge/amperage?
Old 03-29-16, 07:06 AM
T
Received 44 Votes on 43 Posts
If you feel better about it, use the correct ring terminals under the screw. Those screws and pads MIGHT be designed for bare wire, but stranded #10 will be a problem, and I would not do it even with solid.
