Outlet No Juice, Not the breaker
Received 0 Votes
I have an electrical outlet in my kitchen that just stopped working. There is no fuse blown and everything else on the same breaker is working fine. I removed the outlet and tested the wires and there is no juice. How do I fix this and where do I find the problem? Thank you!
Welcome to the forums.
Knowing everything on a circuit is a good thing.
You will need to work backwards. The problem is not at the receptacle that is dead but is most likely at the previous one. Check the next nearest receptacle/device that is live and on that circuit.
If you find receptacles with wires pushed into the back of them.... that is a major issue. The wires need to be moved to the side screws.
Ive checked it with a wire tester
That is the only thing on the circuit that is not working.
*Outlet can be a switch, a light, or a receptacle.
So this is a direct line.... with no splices.... between the panel and the dead receptacle.
What type of tester... a light up neon tester, a non contact tester, a meter with two probes ?
Received 0 Votes
How do I figure out if it is direct to box? But everything else I tried works. The tester is just a simple two prong with a light on the end. What will an analog multimeter do that this isn't telling me? My tester says there is no juice coming through the wires correct?
Received 0 Votes
Another idea...
Make sure there is no GFCI outlet that has tripped. If a GFCI trips, everything after that stops working. Unless your kitchen is older, there is likely a GFCI in there somewhere.
I have a GFCI in my home near the breaker box. It ends up going to an outside outlet. Each year, at least one of the Christmas decorations end up tripping the GFCI. First time it happened, I went crazy trying to figure out why the electric stopped working. The connection wasn't immediately obvious.
Seems like the easiest first step.
Received 0 Votes
I know... I looked and none of our outlets are GFCI. They are the ones with the "test reset" button. I need to update them to be GFCI in the future. There is a blue breaker that I turned off and on and that did nothing either... I also double-checked to make sure all the breakers are pushed all the way on. Any other ideas??
