Trouble testing wire harness on fridge
I have a fridge without power to front display. Fridge runs perfect, but the front display has no power. There are two wire harnesses on control board that go into one harness that connects into board that controls front display.
Trying to confirm that there is power going to last harness, but hard to get into harness pins.
Any easy way to determine if power is coming into last harness that connects to display board?
Welcome to the forums.
With the correct probes those measurements are easy to make. You need test probes with small pins.
You should locate the wiring diagram for the fridge and see what pins need to have power.
There should be a tech sheet/schematic under/behind/above the front kickplate or even on the back.
