Digital temperature controller wiring
Old 05-26-16, 05:51 AM
D
Members location is Switzerland.
I bought a digital temperature controller to convert a fridge into a fermentation chamber.
The idea is to have higher temperatures than the original fridge range.
I watched several videos, but I'm still quite confused about which cable goes where.
Does someone have an idea where the cables from the fridge original controller have to be connected on the digital controller (see photos)?
6 and 7 are for the temperature probe.
Thanks!
Old 05-26-16, 07:39 AM
P
Received 2,256 Upvotes on 2,009 Posts
Where are you located? You have a 220VAC controller and residential fridges in the US are 120VAC. If you're truly using 220V then the 10 amp rating of the controller might be enough. It's cutting it close for one on 120 volts though.
What I do with fermentation temp controllers is all done without disassembling the fridge. Set the fridge thermostat to it's lowest temperature so it's always trying to make the compressor run. I wire an outlet to the temperature controller using it's relay output so the temperature controller turns the outlet on and off. You plug your fridge into that. Doing it this way means you only have to get the temperature probe into the fridge which minimizes the holes you need to drill and it leaves the fridge "stock" in case you ever need to use it as a fridge again.
Here is a wiring diagram I use with LOVE brand temperature controllers. This diagram is for a controller that controls both heating and cooling in the fermentation chamber but the wiring is the same for your controller minus the heating stuff.
Old 05-26-16, 09:08 AM
ray2047's Avatar
Dane, IP indicates O/P's location is Switzerland.
Old 05-26-16, 10:32 AM
Received 4,082 Upvotes on 3,665 Posts
Dane's way illustrates using the thermostat on the power cord instead of connecting at the internal thermostat.
If you want to connect to the internal wiring you would need to post a wiring diagram for the fridge. The diagram will be somewhere on the fridge..... usually the back.
Old 05-26-16, 12:35 PM
D
That's exactly what I had in mind originally.
Leaving the fridge intact is the way to go.
I don't know why most tutorials require to hack the fridge controller.
Thanks a million!
Old 05-27-16, 06:29 AM
D
Here is the final result
I bridged 2 and 4 for more simplicity
Thanks again
Old 05-27-16, 06:38 AM
G
Received 2 Upvotes on 2 Posts
Hacking the fridge controller preserves lights, displays, auto-defrost or anything else that might need constant power--depending on fridge model.
Doing it Dane's way is easier if none of that is a concern.
