GFCI problem
Received 0 Votes
GFCI problem
I replaced the regular outlet on my porch with a Leviton switch and GFCI outlet, 12A/ 125v.
Ran 30ft of 12/2 wire (underground 18in in plastic conduit) to a 20A/125v outdoor outlet, also GFCI. Running 2 fountains, each is 3.2w. 0.06A.
I flip the switch and the fountains turn on.
Everything runs fine but the GFCI for the outdoor outlet pops after about an hour.
The outdoor outlet is on a metal pole.
What do I look for? Doesn't seem the fountains would pull enough power to pop them unless one of them is going bad
You have some intermittent problem with current leakage to the water or to the earth. This is what trips a ground fault circuit interrupter.
Unplug one of the fountains and run the other for a few hours. Then repeat with the first fountain in an effort to find out which one has the current leakage.
