How to make a GFCI outlet independent from others...
Received 0 Votes
Hi,
I had a GFCI outlet in a bathroom that controlled the outlet of two other bathrooms. When I remodeled the other two bathrooms the guy from Home Depot said that I needed a GFCI outlet for each bathroom. I got new GFCI outlets and installed them in each of the new remodeled bathrooms but noticed that when it a short circuit is triggered in a bathroom all three of the GFCIs in the three bathrooms are also triggered. The only way to reset them is to reset the one in the first bathroom (the one with the original GFCI). I am now having problems and when I reset the GFCI outlet in the original bathroom seconds later it triggers ...
Can someone help me making each GFCI independent of the others?
Thank you so much for helping.
Louis
The first picture is from one of the other bathrooms.
This last picture is from one of the the first bathroom.
Louis
One thing to note before moving the wires.
In older houses, outdoor outlets are often protected by the same GFCI. If that is the case, you need to change outdoor outlets to GFCI as well.
GFCI usually works fine even if there is another GFCI on it's load side. GFCI tripping is usually due to ground fault somewhere or bad GFCI. In my experience, it often is outdoor outlet. Moisture and bugs/dirts inside outlet and junction box can cause ground fault. That may be why your original GFCI is tripping.
