Splicing wires together mid-air
Old 06-15-16, 10:03 AM
F
Contractor is installing new a/c compressor alongside the house. He ran flexible metal conduit (MC) from the main panel in the house, through an unfinished basement and into a crawl space. Just before going through the rim joist he transitioned from MC to single strand #10 THHN and ran the single strands in water tight flexible conduit out to a disconnect box mounted on the side of the house. Where he transitioned from MC to single stand in the crawl space it looks like he spliced the wires together and wrapped them in electrical tape. He did not use a junction box. Is this acceptable?
Old 06-15-16, 10:14 AM
Z
Received 427 Upvotes on 380 Posts
Nope, definitely not. All connections need to be in an approved junction box. Also, using electrical tape instead of wire nuts is pretty much a no-no.
The connections should be in a 4x4 metal box or similar. You should definitely have him redo it.
Old 06-15-16, 10:16 AM
ray2047's Avatar
Old 06-15-16, 01:22 PM
I
Received 45 Upvotes on 43 Posts
Sounds like a hack job to me. Should have a junction box, wirenuts and proper transition fittings and anti-short bushings on the MC.
Old 06-15-16, 01:26 PM
pcboss's Avatar
Received 205 Upvotes on 179 Posts
Definitely needs to be fixed.
Old 06-15-16, 05:55 PM
A
Received 92 Upvotes on 84 Posts
Also - cables need to be secured/supported within 12" of box.
Old 06-16-16, 02:30 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
I hope "He" is an air conditioning contractor and not an electrical contractor. Did "He" get a permit for the new condensing unit? Did "He" get a permit for the new electrical work? I hope the whole job will be inspected.
