How to turn 220 volt outlet to 110 volt?
Received 0 Votes
I had jacuzzi on back yard.
Pretty thick electric line left.
It must be 220 volt.
I saw red,black,white and green lines.
I want install regular 110 volt outlet
How can I turn this line to 110 volt line?
I simply thought white and red line or while and black line could make 110 volt.
Is it correct?
When I measure the voltage between W-R or W-B, it shows half of original voltage.
Would it be dangerous?
May I hire electrician?
Thank you.
Hwa
Is it correct?
Thank you.
Hwa
Your spa wiring is a 120/240 volt line. You have two hots (black and red) a neutral (white) and ground (green) Between the two hots you should be 240 volts and between each hot and neutral you should get 120 volts. Between hot and ground you will also get 120 volts, and neutral to ground you should get 0 volts.
If any of the above is not correct, we need to stop and find out why.
Replace the two pole breaker in in the breaker box with a single pole 20 amp breaker and a blank filler for the second opening in the breaker box cover. Connect the black wire to the new breaker and put a wire nut on the red wire. If the black wire is too large for the breaker connect a #12 pigtail to it.
At the spa location install a weather proof GFCI receptacle in a weather proof box. Connect the white and black to the Line side of the GFCI receptacle and green to ground. Use pigtails if the wires won't fit the GFCI.
Is it correct?
Is it correct?
Just pull out? It didn't work.
Side note: If this is an FPE Stablock panel they can be really difficult sometimes.
Received 0 Votes
This is the picture after remove panel.
I turned off main switch for this sub panel.
I tried to remove the breaker.
It didn't work.
How to remove this?
Sorry I am trying this job for the first time.
Electric field detector shows that there in no electrical field after shut down this sub panel.
To remove a breaker from that panel..... push the breaker handle to off and keep pushing the handle and breaker sideways towards the outside of the panel.
This video show the motion needed. You can skip right to 1:50.
you tube/watch?v=MRmPymLyEMk
Received 0 Votes
Thank you. The video helped me a lot.
Ray2047 said "Connect the black wire to the new breaker and put a wire nut on the red wire."
"put a wire nut on the red wire"
What does this mean?
put a wire nut on the red wire What does this mean?
Received 0 Votes
I finished the job like the photo.
And I tested voltage of jakuzzi side on outside.
I measured voltage difference.
(B-black, G...green,R---red,W---white)
My expectation was:
BG 60 BW 120
However it shoes like this:
BG 150, BW 25,BR 25, WR 0,WG 60,GR 60
I don't know what's happening...
#24
Received 0 Votes
Above voltage measure is normal?
I thought Black and White are power,Green is earth.
And Red need be capped.
Above voltage shows it is not possible.
#25
If you are using a digital multimeter any reading less than 100 volts should ignored. The readings show you do not have a neutral. Are you sure the neutral is connected to the neutral bar in the breaker box.
If you are sure the neutral from the new receptacle is connected to the panel neutral bar tell us the voltage between the neutral bar and both of the incoming hots.
#29
Open your main breaker panel and see if that white wire shows up there. If it does, see where it is or is not connected to.
If it is in the main panel, but not connected to anything, cut at the sub panel and connect to neutral bar.
If it is not in the main panel, try pulling on the wire. It is possible there were no use for it before and some one just pushed unused wire into the conduit.
If all else fails, use remaining red wire as neutral. Technically it is violation of NEC, but it will work. Just mark it with white tape so next person working on the panel understands what is going on.
#30
lambition, it is my understanding he never connected the neutral from the receptacle to the neutral bar in the subpanel. Hansoldc, if you would read and follow our instruction and answer our questions you can do it. Is the white wire from the receptacle connected to the neutral bar in the sub panel (breaker box).
#31
#32
Received 0 Votes
You Right!
Thank you for your concern.
I found the white line from Jakuzzi didn't connect to neutral.
I just pulled out it from conduit.
By the way, this tester is analogue or digital?
I measured voltage difference from jakuzzi side.
WR zero
WB slight
WG slight but biggger than WB
GB 110
GR slight
RB slight
My questions are
1, where may I connect the white line in the box? neutral bar?
2, white line and red line from subpanel to jakuzzi is not connected any.
How come it makes some voltage difference between other lines ?
3, If I need connect white line to neutral bar in the box, what line should I use to get 110 volt?
GB ? or BW?
4, Without white, how come jakuzzi used 240 volt?
Thank you.
WR zero
WB slight
GB 110
GR slight
RB slight
My questions are
GB ? or BW?
Thank you.
#33
GB ? or BW?
GB ? or BW?
