Solid wire plain tap joint in Junction Box?
Old 06-24-16, 01:31 PM
C
I didn't wanted to cut the main line for no reason so I decided to use a plain tap joint in junction box. I knew that pigtail is commonly used to join 2 or more wire in junction box and tee or tap joint in knob and tubing.
Will it cause a problem?
Note; 14 awg solid wire. I wrapped it with shrinkable tube.
Old 06-24-16, 01:47 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Tap joints, if I understand you, are not code compliant because they occur outside a junction box. It is difficult to comment on something that isn't done in the U.S.
Old 06-24-16, 02:12 PM
C
Thank you.
Yes, so probably I'm the only person who has done it.
I hope it will not cause a problem in the future.
Old 06-24-16, 03:57 PM
CasualJoe's Avatar
Received 105 Votes on 93 Posts
What country are you in? .................
Old 06-24-16, 03:59 PM
ray2047's Avatar
Philippines, Joe. .
Old 06-24-16, 04:54 PM
Handyone's Avatar
How did you attach the new "pigtail" or wire to the existing #14?
It's good you used shrink tube around it, but it needs to be secured.
So let me ask a question on your behalf culdown... Because I have never done this before in home wiring:
How do you attach one wire to another when you don't want to cut the original wire?
Are there special connectors, or do you solder it, maybe a split crimp sleeve?
Old 06-24-16, 06:09 PM
pcboss's Avatar
Received 112 Votes on 97 Posts
Wonder if they used a Scotch-lok tap like for automotive wiring.
Old 07-09-16, 05:10 AM
C
Like this
I didn't pigtail it at first but in the end, i did used pigtail (wrapped it with shrinkable tube) because it's faster than T splice.
