How to determine hot supply wire
I've acquired an old house - no ground wires. A switch box has two black wires and two white wires which have black tape on them. Without a ground wire, I'm not sure how to determine which wires are hot.
Welcome to the forums.
With or without a ground wire.... the hot and neutrals are the same.
You have two cables. One cable is probably power in and the other cable is light out. That would mean that the two whites would be combined together and you would have the two black wires on the switch.
If you opened the white connection..... you would check from white to black on either cable to see which one was hot.
Just for your information.... by code.... you cannot modify or add a receptacle to an ungrounded circuit.
Sorry, I left out one detail. It's a double switch that fits in a one-gang box. One controls a light in one bedroom and the other controls a light in another bedroom. Not sure what you call that kind of switch.
You can connect one side of your meter to any ground, using a length of wire if necessary. In an older house, a water pipe would be a good bet for a ground.
Failing that, you can use a non-contact voltage sensor. They are not totally reliable, but better than nothing, and when they give a misleading indication it's almost always telling you a wire is hot when it's not.
Are there two switches in the box? Sounds like two switch loops....
It's a double switch that fits in a one-gang box. Not sure what you call that kind of switch
Here is a single simple switch loop. You probably have two in the box.
I think the OP is referring to a stacked switch, 2 switches in a single gang box.
Either way, Ray is probably right. Pick a cable and connect the white and black together, one of the lights should turn on.
Thanks Ray... I missed the part about the whites being taped black. Definitely switch loop situation.
