Replacing razor receptacle with gfci
Hello!
So in my bathroom I had a light switch that use to control a light and a razor only outlet.
I don't have a razor and I want to use my electric toothbrush charger in the bathroom.
So I decided to change it for a gfci. I would really like if the outlet was not dependent of the light.
breaker and gcfi are 15 amps
I looked at a lot of diagrams and I think I found how to. Could somebody double check on my drawing? I just don't want to do all this and then its just not working.
Power source is at the ceiling in the light outlet box
a 4 cable (ground, black, red, white) start there and is going to the razor outlet box
then a 2 cable (black white) from the razor outlet goes to the light switch
I did not draw the ground cables because it was confusing but I plan on wire them all, don't worry
thank you!!
thank you!!
