3-way switch update *almost* works...
One 3-way switch must be left in "on" position? [SOLVED]
Hi guys,
My wife and I just bought a house that was full of incandescent lighting. I replaced all the bulbs with LED equivalents, and where necessary, LED-compatible fixtures.
The lights over the stairs were the only existing LED lights, and they were much too bright. They were recessed units with built-in LEDs, so I couldn't replace the bulbs.
So I thought I'd add a dimmer. There was no guarantee it'd work with the older LED fixtures, but it seemed worth a try before having to replace the fixtures.
The lights are controlled by two 3-way switches, at either end of the stairs. I decided to replace the downstairs switch—the one closest to the breaker board, in case that's important—with a Lutron LED-compatible 3-way dimmer-on/off switch, model DVCL-153PR-WH.
I carefully noted the connections to the existing switch:
• One black wire – to switch's 1st brass screw
• Another black wire – to switch's 2nd brass screw
• White wire – to switch's black screw, marked "COMMON"
There was no ground screw, but one of the box's screws was connected to a ground wire, so the switch was grounded through the box.
Lutron's instructions said:
So I assumed the COMMON wire was the white one, above.
Rather than screws, the dimmer had these wires:
• Black
• Red
• Red w/white stripe
• Green
The instructions then said to connect the ground—so I connected the dimmer's green wire to the box's ground screw. The instructions continued:
So, using the wire nuts provided with the dimmer, I:
• Connected the box's white wire (the one that was connected to the old switch's COMMON screw) to the dimmer's black wire
• Connected the box's two black wires to the dimmer's red and red/white wires, respectively.
When I turned the power back on, the dimmer worked perfectly (yay!). And I found I could turn the lights on and off from either switch.
However, if I turned the lights off at the downstairs switch, flipping the upstairs switch had no effect. Only when the downstairs switch was "on" could the upstairs switch control the lights.
So I turned the breaker back off and reversed the connections to the dimmer's red and red/white wires. Since the instructions said it didn't matter which way they were connected, I figured it couldn't hurt.
This reversed the switches's functionality: Now I could control the lights from the downstairs switch only when the upstairs switch was left "on".
Any idea what I did wrong? Is it possible the wrong wire was connected to the old switch's "COMMON" screw? But then the 3-way switching wouldn't have worked, would it?
Thanks! Sorry to be so long-winded, BTW; I just didn't want to omit anything significant. Cheers, Ander
3-way switches have wires connected to three screws plus a ground screw. One of these wires is connected to a screw of a different color (not green) or labeled COMMON. Tag this wire to identify it when removing.
• Black
• Red
• Green
• Connect the tagged wire to the black wire on the dimmer.
• Connect one of the remaining wires to the red wire on the dimmer.
• Connect the remaining wire to the red/white wire on the dimmer.
Ah—it turns out Lutron has 24/7 tech support. That's impressive.
The tech advised me to try switching the COMMON wire with one of the other (non-ground) wires. I did, and it solved the problem.
My only question is, how could the original 3-way switching have worked if the wiring was the way I had it?
The circuit is pretty straightforward. You more than likely have one of the wires switched for the common.
Those diagrams are labeled in three different languages which confuses the issue. I blanked out most of the other two languages and missed that one.
